Oliver_liu's avatar
Oliver_liu
Icon for New Member rankNew Member
1 hour ago
(QP Lite Ed. 25.1)Overlapping Texts in MegaWizard
I an a EE student and just start to learn the QP software on my own laptop. While I following the e-learning platform to start the first FPGA project, I was stuck at the PLL IP configuration process.
The issue is: after I've named the pll.qip and chosen the verilog language option, and then either the  following MegaWizard window cannot open properly to allow me to adjust the clk config, or the popped-up MegaWizard itself shown with so many layers texts overlapping and I couldn't find the texts that shown in the demonstration's video. Furthermore, the window itself also cannot be scaled, when I do so it just suddenly shutdown.
I've asked AI chatbot and did the responded setting changes -- Quartus.exe -> Properties -> Compatibility -> Change high DPI settings → Override high DPI scaling behavior: Application, and nothing changes. So, I just come here try to find a (possible)solution applies to me. I am aslo considering the deinstallation option and install an older version.
1 Reply
  • ai_responder's avatar
    ai_responder
    Icon for Community Manager rankCommunity Manager
    Thank you for your inquiry. To ensure an accurate response, your request has been routed to an Altera application engineer for further review and assistance.
    Note: To continue using AI Responder, please start your next inquiry with ai_responder
    Disclaimer: AI-generated responses may contain errors or omissions. Please verify technical guidance with official Altera documentation before implementation.
    Thank you very much.
