BrianM
3 years agoqmegawiz generated SRAM simulation model broken
I've tried 21.1 and 21.1.1, the results are the same.
Here is the pertinent data from the generated variation file:
module psu_mgmt_sram (
clock,
data,
rdaddress,
wraddress,
wren,
q);
input c...
sstrell
3 years agoIt looks like q is the top-level signal. Why are you looking at sub_wire0? And q_b is the output from the block RAM itself.
BrianM
3 years agoThanks for the quick reply.
The q output is always 32'hzzzzzzzz
I can see the writes to the RAM happening, but readback always produces zzzzzzzz.
I noticed that sub_wire0 exists in the RAM model that works that was created a long time ago for the original FPGA. But for the new RAM model, there is no sub_wire0.
