qmegawiz generated SRAM simulation model broken
Tested the code posted with a testbench. I'm able to see the signal sub_wire0 in Questa check image attached.
May be can try go to sim tab -> right-click -> Add to -> Wave -> All items in region and below
Sheng
- BrianM3 years ago
Thanks much.
I can't actually see sub_wire0 in the objects windows when I select any of the RAMs that I've attempted to create recently. But it does exist in the old RAMs that were made a while ago.
The odd thing is, I changed a sea of registers to SRAM a few weeks ago to see if it would save much space in the design and it did not and it failed to meet timing. The RAM that I created for that worked fine, no issues, but I went back to the registers so I wouldn't have to re-pipeline the design to add an output register to the SRAM.
Here is a picture of questa showing the missing wire:
sub_wire0 is missing
This morning I tried removing the entire simulation folder to force Platform Designer to do a complete rebuild and it didn't help.
I know I've done something foolish. I just can't figure out what it is.
