16 years ago --- Quote Start --- I had a (mostly) working system for MAX II using Quartus II Version 9.0 Web Edition. Due to some issues during compilation, where the compiler declared that I could not connect an incoming clock signal to a logic device input, I decided to move to the Quartus II Version 9.0 Service Pack 2 Web Edition. After installing QIIV9.0SP2, I got the "standard" warning that the databases were being deleted. I re-complied the function (.BDF format) that was giving problems earlier only to ultimately find a fluke caused by insertion of a component into a wire, then deletion of the center part of the wire spanning the component (I put in an inverter) that was previously causing my error. When the function was fixed, I tried compiling the top-level system, and was treated to a warning: Warning: Entity "TestProject" contains only dangling pins. The BDF for Test Project shows pin assignment boxes next to each IO port. What has happened, and how is it fixed? Thanks, Roger Watkins roger@pervalidus.com --- Quote End --- Hi, could you post your BDF larger ???? Kind regards GPK
