8 years agoQII 17.1 tristate controller IRQ -1 problem
Hello!
I use Quartus II 17.1 Standard edition with Stratix IV device. I have to connect LAN91C111 device. I use QSYS with altera_generic_tristate_controller for it. After generation system.h file for embedded software development: # define ALT_MODULE_CLASS_Lan_controller altera_generic_tristate_controller# define LAN_CONTROLLER_BASE 0x10000# define LAN_CONTROLLER_IRQ -1# define LAN_CONTROLLER_IRQ_INTERRUPT_CONTROLLER_ID -1# define LAN_CONTROLLER_IS_ETHERNET_MAC 1# define LAN_CONTROLLER_LAN91C111_DATA_BUS_WIDTH 16# define LAN_CONTROLLER_LAN91C111_REGISTERS_OFFSET 768# define LAN_CONTROLLER_NAME "/dev/Lan_controller"# define LAN_CONTROLLER_SPAN 65536# define LAN_CONTROLLER_TYPE "altera_generic_tristate_controller" How I can set: LAN_CONTROLLER_IRQ_INTERRUPT_CONTROLLER_ID 0 LAN_CONTROLLER_IRQ 2 ? in the QSYS program, the signals to the interrupt controller are connected and the interrupt is set to 2, but in system.h interrupt controller -1 and IRQ -1 how can I fix it? UART is connected to IRQCONTROLLER also and it has parameters like this in system.h # define LOG_UART_IRQ 0# define LOG_UART_IRQ_INTERRUPT_CONTROLLER_ID 0 The problem is altera_generic_tristate_controller only... in the QSYS program, the signals to the controller are connected and the interrupt is set to 21 Reply
- Michael_Kress
I am having the same problem with a altera_generic_tristate_controller not exporting the IRQ and controller id. When I generate the BSP (in Nios), I have to manually edit system.h to insert correct values.
