I suggest that you consider the use of ieee.numeric_std and VHDL 2008, at least the construts in VHDL 2008 as supported by Quartus at this time. (Altera, we are still waiting for full support of VHDL 2008!)
I put together a quick snippet of code for what I think that you want to do. Note that I use a record type to clarify the PWM signals. There are effectively three states: one during the duty cycle on time, one during the duty cycle off time, and one to reset the counter (which really isn't a state, just a resetting of the pwm counter.) Best, James
architecture RLT of PWMgenerator is
type pwmType is record
drive : std_logic;
dutyCycle : integer range 0 to 2**24;
Period : integer range 0 to 2**24;
end record;
signal pwm : pwmType;
begin
pwm.Period <= someValue; -- (Would come from port I/O)
pwm.dutyCycle <= someIncomingValue; -- (Would come form port I/O)
process(all)
variable counter : integer;
begin
if HRST then
pwm.drive <= '0';
elsif rising_edge(MCLK) then
if counter < pwm.dutyCycle then
counter := counter + 1;
pwm.drive <= '1';
elsif counter < pwm.Period then
pwm.drive <= '0';
else
counter := 0;
pwm.drive <= '0';
end if;
end if;
end process;
