15 years agoHi all,
I was looking about to see if I could find something in an older post, and this was the closest but still hasn't helped me from what I could see. I currently have the error: "error (10822): hdl error at lvds_fifo_control.vhd(210): couldn't implement registers for assignments on this clock edge" But I'm not trying to assign things on the rising and falling edge of a clock in the same process as was explained here. Instead I have 2 clocks, one is 3x the frequency of the other (done using a PLL), and I am basically trying to multplex 24 bit parrallel input and load it into an 8bit wide FIFO. I know my error has something to do with the fact that I am trying to load the first of the 3 bytes into the FIFO when both clocks have their rising edge, Load_FIFO is high, and the FIFO buffer is not full.... but I am not sure what is causing my error.... I have probably done something extremely obvious wrong but can't seem to work it out, as I have little experience with VHDL... If not, is there a better way to implement what I am trying to do?
-- FIFO Loader
FIFO_Loader : process (intRCLK, MULT_CLK, rst, Load_FIFO, FIFO_FULL)
begin
if (rst = '1') then
FIFO_WR <= '0';
Load_State <= Load_IDLE;
elsif ((MULT_CLK'EVENT) and (MULT_CLK='1')) then
case Load_State is
--Idle state....
when Load_IDLE =>
if ((intRCLK'EVENT) and (intRCLK = '1') and (Load_FIFO = '1') and (FIFO_FULL = '0')) then --
FIFO_WR <= '1';
FIFO_IN(0) <= R(0);
FIFO_IN(1) <= R(1);
FIFO_IN(2) <= R(2);
FIFO_IN(3) <= R(3);
FIFO_IN(4) <= R(4);
FIFO_IN(5) <= R(5);
FIFO_IN(6) <= G(0);
FIFO_IN(7) <= G(1);
Load_State <= Load_Byte2;
else
FIFO_WR <= '0';
end if;
when Load_Byte2 =>
FIFO_WR <= '1';
FIFO_IN(0) <= G(2);
FIFO_IN(1) <= G(3);
FIFO_IN(2) <= G(4);
FIFO_IN(3) <= G(5);
FIFO_IN(4) <= B(0);
FIFO_IN(5) <= B(1);
FIFO_IN(6) <= B(2);
FIFO_IN(7) <= B(3);
Load_State <= Load_Byte3;
when Load_Byte3 =>
FIFO_WR <= '1';
FIFO_IN(0) <= B(4);
FIFO_IN(1) <= B(5);
FIFO_IN(2) <= H_Sync;
FIFO_IN(3) <= V_Sync;
FIFO_IN(4) <= Reserved(0);
FIFO_IN(5) <= Reserved(1);
FIFO_IN(6) <= Reserved(2);
FIFO_IN(7) <= Reserved(3);
-- default state - return to IDLE
when others =>
FIFO_WR <= '0';
end case;
end if;
end process FIFO_Loader;
Cheers, Lee H
