9 years agopulse counting
Hello, I'd like to code a pulse counter : after X pulses from a signal, another signal toggles (I choose 4 in my example). I wrote this piece of code, and the behavior is not as i expected...
9 years ago --- Quote Start --- Ok, thank you ! :), I didn't know rising edge on an other signal than a clock was a good practice --- Quote End --- You're not using the rising edge function - you're building a rising edge detector. There is still only a single system clock.
