9 years agopulse counting
Hello, I'd like to code a pulse counter : after X pulses from a signal, another signal toggles (I choose 4 in my example). I wrote this piece of code, and the behavior is not as i expected...
9 years agoCode :
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity pulsegen is
generic (
pulse_to_count : unsigned(7 downto 0) := "00001000"
port(
clk : in std_logic;
reset : in std_logic;
ratio_freq : in unsigned(19 downto 0);
en_in : in std_logic;
pulse : out std_logic;
toggle_pulse : out std_logic
end pulsegen ;
architecture arch of pulsegen is
signal pulse_tick : std_logic :='0';
signal pulse_dir : std_logic :='0';
signal pulse_counter : unsigned(19 downto 0) := (others => '0');
signal counter_dir : unsigned(7 downto 0) := (others => '0');
begin
pulse <= pulse_tick;
toggle_pulse <= pulse_dir;
pulsegen : process (clk)
begin
if rising_edge (clk) then
if reset = '0' then
pulse_counter <= (others => '0');
pulse_tick <= '0';
pulse_dir <= '0';
else
if (en_in <= '1') then
if pulse_counter = ratio_freq then
pulse_tick <= not pulse_tick;
counter_dir <= counter_dir +1;
if (counter_dir = pulse_to_count) then
counter_dir <= (others => '0') ;
pulse_dir <= not pulse_dir ;
end if ;
else
pulse_counter <= pulse_counter + 1;
end if;
else
pulse_tick <= '0';
end if;
end if;
end if;
end process pulsegen;
end arch;
Test Bench : library ieee;
entity tb is
end tb;
architecture behavior of tb is
component pulsegen
generic (
port(
clk : in std_logic;
end component;
signal clk : std_logic := '0';
signal reset : std_logic := '0';
signal en_in : std_logic := '0';
signal pulse : std_logic := '0';
signal toggle_pulse : std_logic := '0';
signal ratio_freq : unsigned(19 downto 0) := "00000000000011111010"; --determines pulse output frequency
constant pulse_to_count : unsigned(7 downto 0) := "00001000"; --toggles every 8 pulses from pulse output
constant clk_period : time := 20 ns; --50MHz
begin
uut: pulsegen generic map(pulse_to_count=>pulse_to_count)
port map(clk=>clk, reset=>reset,ratio_freq =>ratio_freq, en_in=>en_in,pulse=>pulse,toggle_pulse=>toggle_pulse);
clk_process : process
begin
clk <= '0';
wait for clk_period/2;
clk <= '1';
end process;
stim_rx_proc: process
begin
wait for 100 ns;
reset <= '1';
wait for 200 ns;
en_in <= '1';
wait;
end process;
end;
If you use my code and TB you'll see there is something wrong. I'd like to have the "toggle_pulse" toggling every 4 pulses from "pulse".
