Altera_ForumHonored Contributor17 years agoPull-ups/Pull-Down/Slew-Rate I/O pins definitions Hello, Scoured the Quartus/Cyclone-III docs for methods of defining Pull-ups/Pull-Down/Slew-Rate for I/O pins, but to no avail. 1. I understand that most of the device's I/O have interna...Show More
Recent DiscussionsAutomatically added negative node for TDS output doesn't work with Agilex 5Design Space Explorer - *** Fatal Error: Access Violation at 0X000000001E19EB30Tensor block usageError (169008): Can't turn on open-drain option for differential I/O pin HPS_DDR3_DQS_N[1]Highlight similar instances of a selected word fails when scrollingSolved
