13 years ago --- Quote Start --- Just for the records: I checked this one with the altera support, as the "Implement as output of logic cell" didn't work. So the answer is (In my own words): "Implement as output of logic cell" and the VHDL "Keep" attribute are the same - nearly. There is small difference: * "Keep" is already accounted for in the very beginning of the Analysis & Elaboration stage. * "Implement as output of logic cell" is only considered in the Synthesis stage. This makes exactly the difference I see: The output name of a state machine is kept with the "keep"-attribute but not with the logic option. /Emanuel --- Quote End --- Hi, I'm facing the same issue but I do not want to use the keep attribute to avoid buffer insertion. Is there any other way to preserve nodes/pins in the final netlist to set timign constraint ? Alex.
