14 years agoIt depends on how what you describe is synthesized. If your two gates can be combined in a single look-up table element inside the CPLD, then the delay will be exactly the same. Check in the report if the number of used resources is the same, or use the technology mapper to find out how Quartus converted your design to CPLD blocks.
