GDagi1
3 years agoProgramming with .ips and .ekp files in command line
I have a JTAG device and am trying to program it through the command line. I have previously programmed using a .pof through:
./quartus_pgm -m jtag -o "p;/path/bitstream.pof@1"
I would...
FakhrulA_altera
3 years agoHi GDagi1,
You may take a look and see if this is applicable:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/manual/tclscriptrefmnl.pdf (page 76-79)
Fakhrul
- GDagi13 years ago
Hi Fakhrul,
Thanks for the response. That is the document I used to come up with the programming commands above. I still have the following questions:
How to add the .ips file?
Should these 3 commands be sequential or combined in command line?
