9 years agoProgramming MAX 10 with .mif
I'm trying to program a 10M50 on the Altera Development Kit. It's programming fine, but I'm not getting the expected readout over UART (I keep getting a semi-random single number continously), so I'd...
9 years agoI don't see ENABLE_RUNTIME_MOD in the RAM HDL, so what should I map to in the RAM instance?
I could make a quick single-port just to check. Is there another way I can check the (dual-port) RAM functionality? As I mentioned I already simulated it successfully, writing it full it then reading it.
