12 years agoProgramming hardware cable not detected
I'm using Nallatech PCIE-385n a7 version. I've driver and SDK installed without problems, but when I try to flash it I got the following message: aocl flash: Running flash from /home/aitjcize/altera/AOCL/board/pcie385n/linux64/bin Info: ******************************************************************* Info: Running Quartus II 32-bit Convert_programming_file Info: Version 13.0.0 Build 156 04/24/2013 SJ Full Version Info: Copyright (C) 1991-2013 Altera Corporation. All rights reserved. Info: Your use of Altera Corporation's design tools, logic functions Info: and other software and tools, and its AMPP partner logic Info: functions, and any output files from any of the foregoing Info: (including device programming or simulation files), and any Info: associated documentation or information are expressly subject Info: to the terms and conditions of the Altera Program License Info: Subscription Agreement, Altera MegaCore Function License Info: Agreement, or other applicable license agreement, including, Info: without limitation, that your use is for the sole purpose of Info: programming logic devices manufactured by Altera and sold by Info: Altera or its authorized distributors. Please refer to the Info: applicable agreement for further details. Info: Processing started: Wed Sep 25 15:34:14 2013 Info: Command: quartus_cpf --convert flash.cof Info (210033): Memory Map File flash.map contains memory usage information for file flash.pof Info: Quartus II 32-bit Convert_programming_file was successful. 0 errors, 0 warnings Info: Peak virtual memory: 526 megabytes Info: Processing ended: Wed Sep 25 15:34:43 2013 Info: Elapsed time: 00:00:29 Info: Total CPU time (on all processors): 00:00:28 Error (213013): Programming hardware cable not detected Error: quartus_cpf failed at /home/aitjcize/altera/AOCL/board/pcie385n/linux64/bin/flash.pl line 82. aocl flash: failed. I currently only plugging in the board into the PCIE slot. Do I need other cables to program the board? Thanks!
