12 years agoHi again,
Just wanted to give a follow-up to my problem. It seems actually to be my mistake: after double-checking I noticed that there has been some signal swapping on the PCB of our prototype, so the configuration flash did not get the proper signal (nCSO) on its Chip-Select pin. I have re-wired the faulty signal. It's not working yet 100% (it is programming the flash OK but fails to verify) but I have some hope. Alex
