16 years agoHello,
No, I did not yet solve this problem... I have contacted maxim, but they gave me the solution I already tried, and which didn't work... This is de reply I got: there are two things you will need: | | download the altera svf2jam utility: | https://www.altera.com/support/software/download/programming/jam/ (https://www.altera.com/support/software/download/programming/jam/) | dnl-svf2jam.jsp | download the max16046 bsdl file: | http://www.maxim-ic.com/tools/bsdl/max16046_tqfn.bsd (http://www.maxim-ic.com/tools/bsdl/max16046_tqfn.bsd) | | | then follow these steps: | | using the svf2jam program, convert the svf file from our ev kit | software into a jam file. | launch the quartus ii programmer | click add device… | in the select devices dialog, select import…, and choose the bsdl | file for the max16046. put a checkmark next to the device and | click ok. | select the device on the list and click add file…, and choose the | jam file you just created with the svf2jam utility. | program as you usually would. But like I said, I tried this and it didn't work, the quartus programmer didnt recognize the ID of the device. Thx for helping me! Tim
