16 years agoprogrammer only sees ethernet blaster, not usb blaster
hi evryone, am a complete newbie. I run quartus II on win7 x32, but programmer only sees 'ethernet blaster' at 'add hardware', usb blaster is not present at all. There is already a usb blaster folder...
16 years agoWhen you insert the cable into the USB, does it indicates it has found the driver? install the driver located into the altera folder. I face the same problem sometimes , closing the programmer and reopening or re-inserting the usb helps. In your case, most probably the driver is missing.
