17 years ago
programmer doesn't see usb blaster
On a new netbook (Samsung NC10 with XP home, sp3) I installed the quartus II version 8.1 programmer. I also installed drivers for the usb blaster. The programmer keeps saying: No Hardware at hardware setup.
I checked everything more than once. No other FTDI devices. The setup is the same as on my desktop machine (XP pro, SP2). And there it works.
usbblstr.sys in ..../system32/drivers
usbblstr32.dll in ..../system32
usbblstrlang.dll in ..../system32
usbblstrui.dll in ..../system32
Should there be a referecence to usbblstr in my register? Because there isn't.
    Thanks for the reply, I had the same issue with there being old instances of Quartus left behind. I took the bin folder from the first instance and pasted in the newer instance. I also manually initiated Jtag server. It worked for the time being but I'll tell if it sticks once I restart my computer
    Hi all,
    I had this problem now, everything had been working fine, but after PC restart, my programmer stopped to see USB Blaster.
    I have tried everything you have mentioned here. Nothing helped.
    1) Reinstall drivers - DIDN'T HELP
    2) Reprogram EEPROM - DIDN'T HELP
    3) Turn off firewall - DIDN'T HELP
    4) Clean regs and temp files - DIDN'T HELP
    My solution was restart of JTAG server.
    1) Run CMD as administrator
    2) go to \quartus\bin\ (if you are running 64 bit OS, go to bin64)
    3) execute:>jtagserver --uninstall
    4) execute:>jtagserver --install
    5) execute:>jtagserver --stop
    6) execute:>jtagserver --start
    All these commands may help you to unstuck your JTAG recognition.
    Good luck! I hope it will help someone. :)
