Altera_ForumHonored Contributor17 years agoprogrammer doesn't see usb blaster On a new netbook (Samsung NC10 with XP home, sp3) I installed the quartus II version 8.1 programmer. I also installed drivers for the usb blaster. The programmer keeps saying: No Hardware at hardware...Show More
Altera_ForumHonored Contributor17 years agoHow does the USB Blaster show in Control Panel/Hardware Tab?
Recent DiscussionsFailed to run ip-setup-simulation:Compile option not saved (reversed to default)How to fix Error(23782): Failed to find an expected reportSSLC Login Issue – "You need to enroll" loop after OTP verificationFree Licence for Max+PlusII
