8 years agoProgrammer: Add new CFI Flash Device doesn't work
Hi there, I wanted to add a custom Flash device in Programmer (which is listed as compatible (https://www.altera.com/support/support-resources/supported-flash-devices-for-cyclone-v-and-arria-v-...
JSwif
7 years agoI've got the same issue. Did you ever resolve it?
SLabe
7 years agoIf you run Quartus as Adminitrator it should all work well. i.e.:
Note: User flash-defined information is stored in the Windows registry. Therefore, you must have the system administration (administrator) privileges in order to store the parameter in the Define New Flash Device window in the Intel® Quartus® Prime programmer.
