9 years ago"program" missing from OpenCL RTE for DE1 SoC?
Hi -- I'm trying to run the hello_world example from http://www.terasic.com.tw/attachment/archive/836/de1soc_opencl_v02.pdf
However when I type 'aoc program hello_world.aocx' it throws following error: program: The Altera Linux SoC Runtime Environment for OpenCL is incomplete: Can't find /home/root/opencl_arm32_rte/host/arm32/bin/program If I run ./hello_world, it seems to work fine. I'm using the BSP for 16.0 --> http://www.terasic.com/downloads/cd-rom/de1-soc/de1-soc_opencl_bsp_16.0.zip The vector_add demo also fails to work and quites with an invalid binary error Initializing OpenCL Platform: Altera SDK for OpenCL Using 1 device(s) de1soc_sharedonly : Cyclone V SoC Development Kit Using AOCX: vectorAdd.aocx ERROR: CL_INVALID_BINARY Location: ../common/src/AOCL_Utils.cpp:391 Failed to create program with binary5 Replies
Terasic has released a new BSP with the updated aocl utilities. This one ships with program in the correct location.
http://mail.terasic.com.cn/~jmlei/de1-soc/de1soc_opencl_bsp_16.0.zip (https://connect.uwaterloo.ca/owa/redir.aspx?c=zitme87so94b2qylf0pk56f7oxme5u0uhb9sunbmw2uqynbkduhuca..&url=http%3a%2f%2fmail.terasic.com.cn%2f%7ejmlei%2fde1-soc%2fde1soc_opencl_bsp_16.0.zip) --- Quote Start --- Hi -- I'm trying to run the hello_world example from http://www.terasic.com.tw/attachment/archive/836/de1soc_opencl_v02.pdf However when I type 'aoc program hello_world.aocx' it throws following error: program: The Altera Linux SoC Runtime Environment for OpenCL is incomplete: Can't find /home/root/opencl_arm32_rte/host/arm32/bin/program If I run ./hello_world, it seems to work fine. I'm using the BSP for 16.0 --> http://www.terasic.com/downloads/cd-rom/de1-soc/de1-soc_opencl_bsp_16.0.zip The vector_add demo also fails to work and quites with an invalid binary error Initializing OpenCL Platform: Altera SDK for OpenCL Using 1 device(s) de1soc_sharedonly : Cyclone V SoC Development Kit Using AOCX: vectorAdd.aocx ERROR: CL_INVALID_BINARY Location: ../common/src/AOCL_Utils.cpp:391 Failed to create program with binary --- Quote End --- - Altera_Forum
Hi, nachiket
If you do not mind, can I find the download address? - Altera_Forum
hi
i have same problem with de1-soc on "BSP(Board Support Package) for Altera SDK OpenCL 16.0" linux image file. bsp version 16.0 how can i solve it? thanks - Altera_Forum
Please help me ...
--- Quote Start --- Please help me ... --- Quote End --- If you have already tried the latest BSP from Terasic and already read and followed their documents and you still cannot get it to work; you should contact Terasic directly. They are obliged to help you.
