9 years agoprogram failed, can't load driver for OpenCL RTE , DE1 SoC
Hi -- I'm trying to run the hello_world example from http://www.terasic.com.tw/attachment...opencl_v02.pdf (http://www.terasic.com.tw/attachment/archive/836/de1soc_opencl_v02.pdf) However when I t...
9 years ago@moningWYL, did you read terasic's opencl manual (http://www.terasic.com.tw/attachment/archive/836/de1soc_opencl_v02.pdf)? It has step-by-step instructions as to how you can run the hello_world and vector_add examples. You probably didn't run the "source ./init_opencl.sh" command to set up the environment and load the kernel driver.
