14 years agoprogram counter don't work
I write a program about simple cpu in quartuss II v 9.1 sp2 . Beginning I put all instructions to ram then fetch each instruction to Intruction register and decode it .Normally when fetch the program counter must increased by 1 but my program not ,it point the top address of ram forever I don't know to debug it I try many way to debug it but result of simulation remain the same
my code library ieee; use ieee.std_logic_1164.all; use ieee.numeric_std.all; use ieee.std_logic_signed.all; entity CU is port( Reset : in std_logic; Clock : in std_logic; Enter : in std_logic; --enable CU input : in std_logic_vector(7 downto 0)); end CU; architecture behavior of CU is type states is (start,fetch,decode,load,store,add,sub,inputa,jz,jpos,halt); signal y:states; type ram is array(31 downto 0) of std_logic_vector(7 downto 0); signal reg:ram; signal IR:std_logic_vector(7 downto 0); signal A :std_logic_vector(7 downto 0); shared variable pc :std_logic_vector(4 downto 0); signal addr:std_logic_vector(4 downto 0); begin --transition state t: process(Clock,Reset) begin if(Enter='1')then if(Reset='0')then y <=start; elsif(Clock'event and Clock='1')then case y is when start => y <= fetch; when fetch => y <= decode; when decode => if (IR(7 downto 5)="000") then y <= load; elsif(IR(7 downto 5)="001") then y <= store; elsif(IR(7 downto 5)="010") then y <= add; elsif(IR(7 downto 5)="011") then y <= sub; elsif(IR(7 downto 5)="100") then y <= inputa; elsif(IR(7 downto 5)="101") then y <= jz; elsif(IR(7 downto 5)="110") then y <= jpos; elsif(IR(7 downto 5)="111") then y <= halt; else y <= decode; end if; when load => y <= start; when store => y <= start; when add => y <= start; when sub => y <= start; when inputa =>if(ENTER='0')then y <= inputa; else y <= start; end if; when jz => y <= start; when jpos => y <= start; when halt => y <= halt; when others => y <= start; end case; end if; end if; end process t; O: process(y) begin --three bits on left is command the others is address reg(0) <="10000000"; reg(1) <="00111110"; reg(2) <="10000000"; reg(3) <="00111111"; reg(4) <="00011110"; reg(5) <="01111111"; reg(6) <="10110000"; reg(7) <="11001100"; reg(8) <="00011111"; reg(9) <="01111110"; reg(10)<="00111111"; reg(11)<="11000100"; reg(12)<="00011110"; reg(13)<="01111111"; reg(14)<="00111110"; reg(15)<="11000100"; reg(16)<="00011110"; reg(17)<="11111111"; case y is when fetch => IR<=reg(to_integer(unsigned(pc))); pc:=pc+1; --problem pc is not increased by 1 when load => addr<=IR(4 downto 0); A <=reg(to_integer(unsigned(addr))); when store => addr<=IR(4 downto 0); reg(to_integer(unsigned(addr)))<=A; when add => addr<=IR(4 downto 0); A<=A+reg(to_integer(unsigned(addr))); when sub => addr<=IR(4 downto 0); A<=A-reg(to_integer(unsigned(addr))); when inputa => A<=input; when jz => if(A="00000000")then pc:=IR(4 downto 0); end if; when jpos => if(A>"00000000")then pc:=IR(4 downto 0); end if; when others => IR<=reg(0); end case; end process o; end behavior; if somewhere of the code is wrong or not very well and information that I tell to you is not clear please give some advice because I don't quite have experience in vhdl and english language.Thank you for every answers.
