Product Enhancement Suggestion
I would really like to see Quartus implement all of the "selection statement" functionality described in IEEE 1800-2017, Section 12.5. I tried to use a case-inside statement and Quartus does not support that feature of the language.
Tucker Zischka
- SyafieqS
Hi Tucker,
Thank you for the feedback. I will file a enhancement to the developer regarding this.
May I know if it is possible to attach small test case in qar for this cases?
- TuckerZ
What do you mean by a test case in qar for this cases?
Tucker Z
- SyafieqS
I mean a small design that replicable to be used as test case showing the unsupported feature
- TuckerZ
Here is a snippet of code:
package command_pkg; typedef enum logic [2:0] { op1, op2, op3, op4, op5, op_null } operation_t; end package module command import command_pkg::*; ( input wire [7:0] cmd_decoded, output operation_t command_details ); always_comb begin case (cmd_decoded) inside 8'b????1101: command_details = op1; 8'b????1001: command_details = op2; 8'b????1110: command_details = op3; 8'b00000000: command_details = op4; 8'b????0110: command_details = op5; 8'b????0111: command_details = op_null; 8'b????0100: command_details = op_null; default: begin command_details = op_null; end endcase end endmodule
- SyafieqS
Tucker,
Thanks a lot this should be sufficient and I will forward this to the developer.
Let me know if there is any more concern on this.
We appreciate your valuable feedback.
- SyafieqS
p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution, give Kudos and rate 10/10 survey
