Altera_ForumHonored Contributor16 years agoProcessing images in SRAM(DE2 board) Hello, I've been having some problems trying to process images that I load in the SRAM of the DE2 board, what I do is that I use the DE2 control panel in order to easily load the greyscale raw data o...Show More
Altera_ForumHonored Contributor15 years agohow to add sram in de2 board in sopc? i cant find it in sopc. pls help. thanks
Recent DiscussionsHow to fix Error(23782): Failed to find an expected reportMailbox Client IP - SEND_CERTIFICATE command through FPGA fabricQuartus Prime license rehosted, unable to runFailed to run ip-setup-simulation:Connection bit order between hierarchy
