Processing Cyclone III project converted to Cyclone 10 LP gives EPCS pin configuration error.
I have converted my project to Cyclone 10 LP FPGA and during processing of the project I got the following errors:
Error (12002): Port "data0_to_the_epcs_controller" does not exist in macrofunction "inst"
Error (12002): Port "dclk_from_the_epcs_controller" does not exist in macrofunction "inst"
Error (12002): Port "sce_from_the_epcs_controller" does not exist in macrofunction "inst"
Error (12002): Port "sdo_from_the_epcs_controller" does not exist in macrofunction "inst"I have configured the EPCS-controller pins to "use as regular I/O".
I need to write to the EPCS-eeprom after configuration because I want to remote update my system.
Can anybody help me?
Wamor
- Vicky1
Hi Wamor,
Can you please check the below solution,
Best Regards
Vikas Jathar
- WMor
Hello Vikas,
I am using Quartus Prime Lite Edition version 18.0.0. To generate the MegaCore I can only select Platform Designer. I have no choice to select QSys.
When I select my NIOS processor then right-click and select Open Design File then Platform Designer will be opened. After generating the processor and proces the project in Quartus I got the above mentioned errors.
Any idea what is happening? Should I rebuild my NIOS processor completely with the Platform Designer to fix the error?
Wamor
- Vicky1
Hi Wamor,
Actually cyclone 10 lp does not support legacy epcs/epcqx1 flash controller ip. so use either using ASMI Parallel IP or ASMI Parallel II IP which has similar feature refer the following link,
https://www.altera.com/en_us/pdfs/literature/ug/ug_altasmi_parallel.pdf
https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/ug/ug-asmi2.pdf
I tried to replicate the issue & I came across different errors but eventually I could able to do by rebuilding NIOS & ASMI Parallel IP(Instead EPCS controller).
Best Regards
Vikas Jathar
