WMor
8 years agoProcessing Cyclone III project converted to Cyclone 10 LP gives EPCS pin configuration error.
Hello, I have converted my project to Cyclone 10 LP FPGA and during processing of the project I got the following errors: Error (12002): Port "data0_to_the_epcs_controller" does not exist in macro...
Vicky1
8 years agoHi Wamor,
Actually cyclone 10 lp does not support legacy epcs/epcqx1 flash controller ip. so use either using ASMI Parallel IP or ASMI Parallel II IP which has similar feature refer the following link,
https://www.altera.com/en_us/pdfs/literature/ug/ug_altasmi_parallel.pdf
https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/ug/ug-asmi2.pdf
I tried to replicate the issue & I came across different errors but eventually I could able to do by rebuilding NIOS & ASMI Parallel IP(Instead EPCS controller).
Best Regards
Vikas Jathar
