Ok Fair enough, I have used state machines as variables in both simulation and in my build and I havent noticed any problems. Can you elaborate as to why you dont use them as variables?
If I change the procedure to not use the state machine:
PROCEDURE procedure_example ( SIGNAL clk_i : IN std_logic;
SIGNAL reset_i : IN std_logic;
SIGNAL empty : IN std_logic;
SIGNAL rdreq : OUT std_logic) IS
VARIABLE rdreq_ip : std_logic;
BEGIN
IF(reset_i = '1') THEN
rdreq <= '0';
rdreq_ip := '0';
ELSIF(clk_i = '1' AND clk_i'EVENT) THEN
IF(empty = '0' AND rdreq_ip = '0') THEN
rdreq <= '1';
rdreq_ip := '1';
ELSIF(rdreq_ip = '1') THEN
rdreq <= '0';
rdreq_ip := '0';
END IF;
END IF;
END PROCEDURE;
If I call this like I did with the previous procedure rdreq never gets set. I took both procedures and put them in processes and they behaved as expected. I am not sure what but im obviously missing some feature of procedures or am using them for the wrong purpose. It would be great to work out what im missing!
James
