Ok instead of cutting down here is a full simulation file that I am using in modelsim with comments etc. Attached is a image of the wave I am getting. At the cursor you can see that the rdreq signal gets set when the empty signal goes low. It stays set.
-- File : test_procedure.vhd
-- This component is to test the procedure vhdl functionality
LIBRARY ieee;
USE ieee.std_logic_1164.all;
USE ieee.numeric_std.all;
LIBRARY altera_mf;
USE altera_mf.altera_mf_components.all;
ENTITY test_procedure IS
END ENTITY;
ARCHITECTURE test OF test_procedure IS
-- scfifo component
COMPONENT scfifo IS
GENERIC
lpm_width : natural;
lpm_widthu : natural;
lpm_numwords : natural;
lpm_showahead : string := "OFF";
lpm_type : string := "scfifo";
lpm_hint : string := "USE_EAB=ON";
intended_device_family : string := "Stratix";
underflow_checking : string := "ON";
overflow_checking : string := "ON";
allow_rwcycle_when_full : string := "OFF";
use_eab : string := "ON";
add_ram_output_register : string := "OFF";
almost_full_value : natural := 0;
almost_empty_value : natural := 0;
maximum_depth : natural := 0
PORT
data : IN std_logic_vector(lpm_width-1 DOWNTO 0);
clock : IN std_logic;
wrreq : IN std_logic;
rdreq : IN std_logic;
aclr : IN std_logic := '0';
sclr : IN std_logic := '0';
q : OUT std_logic_vector(lpm_width-1 DOWNTO 0);
usedw : OUT std_logic_vector(lpm_widthu-1 DOWNTO 0);
full : OUT std_logic;
empty : OUT std_logic;
almost_full : OUT std_logic;
almost_empty : OUT std_logic
END COMPONENT;
-- create procedure to read data out of fifo when not empty
PROCEDURE procedure_example( SIGNAL clk_i : IN std_logic;
SIGNAL reset_i : IN std_logic;
SIGNAL empty : IN std_logic;
SIGNAL rdreq : OUT std_logic) IS
TYPE state_machine IS
check_empty,
clear_rdreq
VARIABLE state : state_machine;
BEGIN
IF(reset_i = '1') THEN
state := check_empty;
rdreq <= '0';
ELSIF(clk_i = '1' AND clk_i'EVENT) THEN
CASE state IS
WHEN check_empty =>
IF(empty = '0') THEN
rdreq <= '1';
state := clear_rdreq;
END IF;
WHEN clear_rdreq =>
rdreq <= '0';
END CASE;
END IF;
END PROCEDURE;
-- create signals for test
SIGNAL clk : std_logic;
SIGNAL reset : std_logic;
SIGNAL data : std_logic_vector(15 DOWNTO 0);
SIGNAL wrreq : std_logic;
SIGNAL almost_full : std_logic;
SIGNAL q : std_logic_vector(15 DOWNTO 0);
SIGNAL rdreq_signal : std_logic;
SIGNAL empty_signal : std_logic;
BEGIN
-- example fifo instance
example_fifo : scfifo
GENERIC MAP
lpm_width => 16,
lpm_widthu => 3,
lpm_numwords => 8,
almost_full_value => 4
PORT MAP
clock => clk,
aclr => reset,
data => data,
wrreq => wrreq,
almost_full => almost_full,
q => q,
rdreq => rdreq_signal,
empty => empty_signal
-- create clk
test_clk : PROCESS
BEGIN
clk <= '0', '1' AFTER 10 ns ;
WAIT FOR 20 ns ;
END PROCESS;
-- drive reset
test_reset : PROCESS
BEGIN
reset <= '1';
WAIT FOR 100 ns;
reset <= '0';
WAIT FOR 100 us;
END PROCESS;
-- call procedure concurrently
test_procedure : procedure_example
clk_i => clk,
reset_i => reset,
empty => empty_signal,
-- fill fifo with dummy data to test procedure
test_fill_test_fifo : PROCESS(clk,reset)
check_full,
clear_wrreq
VARIABLE count : integer := 0;
BEGIN
IF(reset = '1') THEN
state := check_full;
count := 0;
data <= (others => '0');
wrreq <= '0';
ELSIF(clk = '1' AND clk'EVENT) THEN
CASE state IS
WHEN check_full =>
IF(almost_full = '0') THEN
data <= std_logic_vector(to_unsigned(count,16));
wrreq <= '1';
state := clear_wrreq;
END IF;
WHEN clear_wrreq =>
wrreq <= '0';
count := count + 1;
END CASE;
END IF;
END PROCESS;
END ARCHITECTURE;
