Yes I do, I cut down the code a bit too much. I drive the clock and the reset and the empty and rdreq signals are connected to the read side of a scfifo
test_clk : PROCESS
BEGIN
clk <= '0','1' ADTER 10ns;
WAIT FOR 20 ns;
END PROCESS;
test_reset : PROCESS
BEGIN
reset <= '1';
WAIT FOR 100 ns;
reset <= '0';
WAIT FOR 100 us;
END PROCESS;
example_fifo : SCFIFO
GENERIC MAP
width => 16,
numwords => 8,
widthu => 3
PORT MAP
clk => clk,
reset => reset,
data => data,
wrreq => wrreq,
full => full,
q => q,
rdreq => rdreq_signal,
empty => empty_signal
The fifo is being filled with data from another component which I have simulated and is working correctly. Data is coming out of the fifo in the simulation as the rdreq is held high but this is not the desired functionality.
James
