14 years ago
Problems with Qsys Avalon UART Rx Interrupt
Hey Guys, I have problems with the Avalon UART Rx Interrupt Generation.
I'm sending several ascii-signs to my UART but there is absolutely no reaction. Neither in simulation nor in synthesis. The Interrupt is definitely not generated and the signs are not adopted. If i force the rxd-pin in ModelSim, there is no effect...
The transmit interrupt in contrast works absolutely fine. No problems with it.
By the way I have enabled all interrupts, not just the Rx and Tx and there is also no "Error Interrupt".
Is there any workaround I did not found yet?
Thanks a lot.
    Actually I'm using my own 32-Bit Softcore. But I monitor the Avalon Irq-Signal on an external Pin from my FPGA. And when I'm transmitting a character there is an IRQ, but NOT at an Rx. And yes, the UART signal arrives at the FPGA ;)
    I don't know the details, but interrupt won't work if there will be no avalon slave register assigned to it for interrupt clearing. The interrupt fires and then YOU need to clear the flag of it.
    Yeah, but the Interrupt does not fire at all. In simulation the IRQ Flag is also not being set if i stimulate/force the "rxd"-pin of the UART, and of cource the slave register (control, status, txdata, rxdata,...) are accessable and are being accessed by my core.
    Then create a SR if You've read the docu and You're sure that everything are within specs.
    Well, perhaps I'll do that because I can't see the causative error... :(
    Ok, I analyzed the UART Simulation System more deeper with the ModelSim Debug option and.. well, please correct me, but it seems that the rxd-pin path into the UART systems ends in the "Uart_rx_stimulus_source" and isn't assigned somewhere else.
    Hi, I have another question concernig the IRq acknowledgement of the UART Core.
    Fore examle if there is an Tx Interrupt, then the belonging bit in the status register is set and i have to read the status register. But how do I clear the IRQ or acknowledge it, better said, how do i reset the irq-bit?
    In the UART Core Spec. there is the annotation that "Writing zero to the status register clears DCTS, E, TOE, ROE, BRK, FE and PE bits".
    At the moment, if there is an Tx IRQ, my IRQ pins goes from Low to High, I read the status register, I set the status register tx-irq-bit to zero (of cource with no effect), and the IRQ Pin remains high and goes never again to Low Level.
    Hi Michi,
    Are you able to resolve your problem?
    I am facing the same problem. Would you please share the solution if any?
    Krupesh
    as I can remember I decided me to use a different IP because i was not able to fixed the mentioned problem...
    Sorry.
    Greetings
    Michael
