16 years agoAs the warning says, you can have only one data vector. You should put together the real and imaginary parts of the sample in one single 36-bit data vector.
You need to instantiate your SOPC system in your top level file. If you use the graphical tools, SOPC builder generates a bdf file for you and you can integrate the symbol in your design. If you use vhdl you can have a look at the bottom of the fir_fft_sopc.vhd and look for the test bench. You can them copy-paste the code that declares and instantiate your SOPC component.
