12 years agoOh, that's strange! I wrote an answer yesterday, but somehow it didn't appear here until now...
First of all, thanks to everybody for your help! @Tricky: You are right! I did run through the synthesis with only one process used (like PietervanderStar suggested) and blasted the FPGA resources... @Daixiwen: Thanks for the suggested document. Yes, I actually had a look at this document and this example. Do you know if I might hit some troubles using this together with the RAM initialisation (page 13-35, example 13-28)? @FvM: Thanks for the suggested code. I actually started from the scratch with this code and at some point I just did something wrong so I hit this error. I think the biggest problem is that I actually didn't get a RAM out of my design. So far I used the following attributes:
SHARED VARIABLE v_memory : ramtype;
ATTRIBUTE ramstyle : STRING;
ATTRIBUTE ramstyle OF v_memory : VARIABLE IS "M10K";
Since I'm using a Cyclone V, I thought Quartus would use the M10K without any troubles. But it turned out it doesn't: can't infer memory for variable 'v_memory' with attribute '"M10K"'. Are there any restrictions which I didn't find in the documents yet (I'm using the "Internal Memory (RAM and ROM) User Guide"? Thanks everybody for your help! I wish you a great and sunny weekend!
