12 years agoIt is strange that you didn't get an error the first time. It could be that Quartus managed to do an optimization or synthesize your code as a memory block before it cold realize that you had two processes writing to the same signal.
Did you have a look at Altera's recommended hdl coding styles (http://www.altera.com/literature/hb/qts/qts_qii51007.pdf) document? Example 13-25 on page 13-33 describe a dual port memory with byte enable signals.
