10 years ago
Problems running aoc under 15.1
Yesterday I downloaded and installed SDK for OpenCL v15.1 (Linux). This I got up and running but today when I try to run aoc on an Arria 10 dev kit I get the following message:
aoc --report -v --board attila_tom host/src/cl/kernel.cl -o bin/kernel.aocx
aoc: Use Quartus Prime Standard Edition for non A10 devices. Current Quartus Version is:
Quartus Prime Beta Shell
Version 15.1.0 Build 185 10/21/2015 SJ Pro Edition
Copyright (C) 1991-2015 Altera Corporation. All rights reserved.
I am unable to discover why I am getting the message, is it perhaps confused because Quartus is returning "Quartus Prime Beta Shell"?
Does my QUARTUS_ROOTDIR_OVERRIDE needs to point elsewhere (it is currently pointing to "altera/15.1/quartus")? I have successfully set up and installed the attila_tom BSP, this is confirmed by aoc --list-boards, so aoc should realise that I am wanting to target an Arria 10.
Any ideas gratefully received,
Neil
    you running the 15.1 with the previous version still installed?
    Yes, but all my environment variables have been changed to just point to 15.1
    I have installed altera OpenCL SDK 14.1 on my computer, but when I compiled the host program in the vs2010, I got the following errors:
    1>LINK : warning LNK4044: unrecognized option '/LC:\work\Temp\arrow_c5sockit\arm32\lib'; ignored
    1>LINK : warning LNK4044: unrecognized option '/lalterahalmmd'; ignored
    1>LINK : warning LNK4044: unrecognized option '/lalterammdpcie'; ignored
    alteracl.lib(acl_globals.obj) : error LNK2019: unresolved external symbol acl_hal_get_system_definition referenced in function acl_init_from_hal_discovery
    D:\software\altera\exmaple\hello_world\bin\hello_world.exe : fatal error LNK1120:
    can you figure out the problem for me ? Thanks!
    D:\software\altera\exmaple\hello_world\bin\hello_w orld.exe : fatal error LNK1120:
    I have tried this out on 16.1. Will need to set the env variable AOCL_BOARD_PACKAGE_ROOT
    to the board package (the folder that contains the board_env.xml).
