9 years agoProblems probably related to signal propagation (timeQuest questions)
Hi, I have a Terasic DE-10lite board (MAX10 based) and I have designed a controller (in verilog) for the SDRAM on the board. Simulating the project with modelsim, the controller behaves exactly as i ...
9 years agoHi Tricky, thanks for the reply. I use an sdc file with some timing specs. I attach the verilog file that i used and the sdc file.
bit.ly/sdram_vga-v (http://bit.ly/sdram_vga-v) (top module) bit.ly/sdram_controller-v (http://bit.ly/sdram_controller-v) bit.ly/sdram_vga-sdc (http://bit.ly/sdram_controller-v) Thanks to all.
