11 years agoThank You for your replies !
--- Quote Start --- It is hard to tell if there is a problem with the algorithm or the compiler. I recommend that you update to the new 14.1 version, which includes some bug fixes. You can also try performing the matrix vector-product using uchar, but storing the final data as int? This may narrow down the problem and may be a work-around solution. If these do not work, you can open a service request and share your code; then the Altera team can find the root cause of the problem. --- Quote End --- Yes, I'll try 14.1 As for matrix-vector product, it is done according to your recipe - using uchar, but storing in int (in short int in fact). How can I open a service request ? Thanks !
