MVrbj
7 years agoProblem with watchdog (Dualboot with encryption)
Hi, i'm trying to use encryption with watchdog(dualboot) on MAX 10 device but without success. Dualboot with watchdog without encryption works flawlessly. Same with dualboot with encryption without ...
ShafiqY_Intel
7 years agoHi MVrbj,
When you generated .pof file, did your both .sof file used the same key?
Both .sof file need to be encrypted with the same key.
- MVrbj7 years ago
Hi WolfGang,
Thank you for your reply. Yes, they are. You can see this in attached .cof files.
I also noticed that not only content of generated .ekp files is different, but also sizes. Shouldn't they both have same size?
Martin
- ShafiqY_Intel7 years ago
Hi MVrbj,
May I know your issue status? Any improvement/workaround?
