Altera_ForumHonored Contributor11 years agoProblem with the programmer for a VHDL code Hello to all. I made a code to make a RS232 connection between my PC and my Stratix II. Now I'd like to implement it on the card to test it. I'm a begginer in VHDL and in Quartus, and in el...Show More
Altera_ForumHonored Contributor11 years agoDid you run all the way through a compile and run the assembler?
Recent DiscussionsFailed to run ip-setup-simulation:Compile option not saved (reversed to default)How to fix Error(23782): Failed to find an expected reportSSLC Login Issue – "You need to enroll" loop after OTP verificationFree Licence for Max+PlusII
