10 years agoProblem with the error Top partition does not contain any logic
Hellow, my problem is that my code compile until 50%, but this show me the error Top partition does not contain any logic, this code is my test bench of other code with 2 inputs with the specify bits for each one and the output of 4 bits. I am trying with this code a clock for each bit with diferent period and iam trying to prove some inputs.
`timescale 1ns / 1ns //clock generation using initial and always statements module TodoUnido_V (); reg [9:0]A; reg [5:0]B; wire [5:0]Dia; TodoUnido DUT (A[9:0],B[5:0],Dia[4:0]); initial begin A[9] = 1'b0 ; # 5 A[9] =~ A[9]; A[8] = 1'b0 ; //#10 //A[8] =~ A[8]; A[7] = 1'b0 ; # 5 A[7] =~ A[7]; A[6] = 1'b0 ; //#5 //A[6] =~ A[6]; A[5] = 1'b0 ; # 5 A[5] =~ A[5]; A[4] = 1'b0 ; //#5 //A[4] =~ A[4]; A[3] = 1'b0 ; # 5 A[3] =~ A[3]; A[2] = 1'b0 ; //#5 //A[9] =~ A[9]; A[1] = 1'b0 ; # 5 A[1] =~ A[1]; A[0] = 1'b0 ; //# 5 //A[9] =~ A[9]; B[5] = 1'b0 ; # 160 B[5] =~ B[5]; B[4] = 1'b0 ; //# 160 //P[5] =~ P[5]; B[3] = 1'b0 ; # 160 B[3] =~ B[3]; B[2] = 1'b0 ; # 160 B[5] =~ B[5]; B[1] = 1'b0 ; //#160 //P[1] =~ P[1]; B[0] = 1'b0 ; //# 160 //P[0] =~ P[0]; end //determine length of simulation initial # 400 $finish; endmodule2 Replies
- Udith
Try this.. It worked for me...
First make the Module code as the top level entity (not the test-bench) then compile...
This design does no contain any logic, because it appears to be test code.
What is the DUT? have you tried synthesising that on its own?
