15 years agoThat is how I would have wired it. As the PLL I would suggest 50Mhz and -3ns Phase shift. You can easily find many threads for the DE2 here in the forum suggesting this values. Perhaps post a picture of your sopc sytem and describe your SDRAM settings. Have you got the chipselect and banks right?
!!!I forgot to mention one thing, your dq pin must be bidirectional. You can read dq to and from the ... so your pin allows only to give data to the sdram, but not getting something, change that accordingly. It's the green connection at the cpu!!! Yours, Peter.
