15 years ago --- Quote Start --- I have a system with SDRAM controller core to connect to SDRAM chip on DE2 board. I know I will need to connect a PLL to the SDRAM clock signal, however I cannot figure out how to do this from my block schematic file. If I create a PLL from megafunction, how can I integrate it with my system? I have attached the top level block schematic diagram. If any other files are needed I will be happy to provide Chase --- Quote End --- Hi, when generating a PLL with the megawizard a symbol for the PLL is also generated. You only have to double-click into your schematic and in the opening window you should find your symbol under the "project" directory. Kind regards GPK
