9 years agoProblem with parameters when instantiating custom build component
Hi to all I'm new here, so I hope this is the right Forum... I have a problem with a self made IP Component. I wrote the code in VHDL and build a Custom Component out of the *.vhd with Qsy...
FHint
3 years agoHi,
I hope it's okay to revive this thread.
I have had the same problem and solved it by adding a dummy interface to the component whose width was controlled by an otherwise unused generic, that had to be changed from intance to instance.
I called the generic channel_id:
add_parameter channel_id integer set_parameter_property channel_id DEFAULT_VALUE 1 set_parameter_property channel_id ALLOWED_RANGES 1:64 set_parameter_property channel_id HDL_PARAMETER true set_parameter_property channel_id AFFECTS_ELABORATION true set_parameter_property channel_id AFFECTS_GENERATION true
And the interface dummy:
# # connection point dummy # add_interface dummy conduit end set_interface_property dummy associatedClock "" set_interface_property dummy associatedReset "" set_interface_property dummy ENABLED false set_interface_property dummy EXPORT_OF "" set_interface_property dummy PORT_NAME_MAP "" set_interface_property dummy CMSIS_SVD_VARIABLES "" set_interface_property dummy SVD_ADDRESS_GROUP "" add_interface_port dummy dummy_o dummy Output
As you can see the ENABLED property is set to false, so the interface is not even shown in the platform designer.
In the ellaboration callback I set the width of the output port to the channel_id:
set_port_property dummy_o WIDTH_EXPR "channel_id"
In the VHDL code of the component I added the port, too:
dummy_o : out std_logic_vector(channel_id-1 downto 0);
With these few lines added to the TCL and VHDL files there were individual instantiations created.
I hope this solution works for other users too. I used Quartus Prime 21.1 SE.
Florian
