9 years agoProblem with parameters when instantiating custom build component
Hi to all I'm new here, so I hope this is the right Forum... I have a problem with a self made IP Component. I wrote the code in VHDL and build a Custom Component out of the *.vhd with Qsy...
9 years agoHi
Here is an update to my Problem. I build another custom component with generics. And this one works fine. I have also instantiated it a few times. When generating the System Qsys doesn't generate those system_... .vhd files in the \System\synthesis folder of my project. It refers directly to the component within my VHDL Script. I checked all the differences between the new component that works and the older one which doesn't. But i found no mistake. I'm really in a bad end with this. Does anyone know what triggers the generating of this system_... .vhd files in the \System\synthesis folder??? Thanks.
