9 years agoProblem with parameters when instantiating custom build component
Hi to all I'm new here, so I hope this is the right Forum... I have a problem with a self made IP Component. I wrote the code in VHDL and build a Custom Component out of the *.vhd with Qsy...
9 years agoWeird. I presume each instance of the custom component in the Qsys system has its own unique name.
How did you set up the parameters in the Component Editor? They must all be set to editable. How are the parameters set up?
