15 years agoYes. Having a create_clock assignment on a register basically means that clock "just appears" there. It's edge starts there at time 0. The clock for clk also starts at time 0, but has a long delay to rx_clk, and hence the large clock skew causes a hold violation. Making a generated clock that works is the best method. (And I never enter constraints in the console. Always put them in the .sdc. If you want to enter them via the GUI, open the .sdc in Quartus and go to Edit -> Insert Constraint).
Now that the generated clock is correct, the delay to clock rx_clk is accounted for, the skew goes away, and it meets timing.
