Problem with FIR II filter
Sorry for the delay. I have performing different tests to narrow down the problem. I found that the errors are related to the number of coeff taps are not sufficient to achieve your interpolation. I have tested increasing the coeff no. in the "Coefficients" tab of the IP Editor to a dummy amount of 147 and the errors go away. Sorry as I am not a FIR specialist and could not really comment the right coeff no. to use for your specific case. You might need to further explore into this.
Chee Pin
- pavanhegde5 years ago
Hello all,
I am also following same issue.
Is there any document or method for considering or calculating number of taps for FIR filter.
In the IP if we import coefficient file it will automatically shows the error is gone (as @CheePin_C_Intel mentioned )
Thank youRegards
Pavan
