12 years agoSorry I made a mistake when I reported the line.
The line that I wanted to refer is this:met <=met+1; With this code I wanted to do the addition operation. I wanted the variable 'met' to be zero when we insert in the loop FOR i IN 1 TO 25 LOOP met <=met+1; END LOOP; and then to be increased so as finally to be equal to 25. This is a simple code that I tried to do because I try to write a code and there the variable 'met' is a fixed point number and I added it with a fixed point number.
