8 years agoProblem with 128Bits from RTL module and Opencl
I have an output from RTL module with 128 bits width and I want to transfert this output to global memory for print in linux terminal. So, I know the type of 64 bits is unsigned long and What's th...
zjinf
6 years agoHow did you fix it ???? i have the same problem, but altera or intel user guide give no explain or example for it , i have 128 bit RTL output, that is 4 32 bit int for kernel, i can't received form the kernel in parallel( i want RTL parallel out), but i don't know how to write kernel code interface
